PM APN automatically switches to PC mobile for data usage.I have a Redmi 4A
smitty267
Why does the APN on my phone switch? Is it supposed to and is that ok.?.Data seems to not work with the public APN very well..I checked and rechecked the settings.  Any one else have this issue and how did you resolve it?. Thanks!
14 REPLIES 14
smitty267
Hey thanks!.. It works that way for me too ..So Just not gonna fix it it.
smitty267
I reset the settings and let the phone do it's thing,,seems to work now using PC Mobile default settings..I didn't actually set it up PC-Mobile ..it just showed up...I won the phone in a contest soo who knows.  It works..so if it ain't broke? Thanks for taking the time to help.
@smitty267 wrote:
Screenshot Posted
@smitty267  The PC-Mobile APN is in fact the Public Mobile APN settings not sure why you called it PC-Mobile? Maybe at one point you were signed up with them and then you modified the APN settings to work with PM. Anyway, I think you should reset your APN settings to default and then manually add the Public Mobile APN settings as per Simon's recommedations (? bottom right of your screen type APN settings)
Tweetynumair
My dad seems to be experiencing the same thing although he says the PC mobile apn seems to work fine for the data.  He's also on a Xiaomi phone.  It only started recently after he went on a trip and used 2 other sims in the phone.  When he came back, the phone would auto choose Telus apn and when we selected Public mobile apn, it would mysteriously change to pc mobile but the data continued to work.
Doesn't really help you, I know, but at least you're not alone!
smitty267
Screenshot Posted
smitty267
Android version 7.1.2,  & MIUI 10.2.3
smitty267
I'm starting to think it's the phone as well.
smitty267
Screenshot_2019-12-18-07-49-04-423_com.android.settings.pngScreenshot_2019-12-18-07-51-34-977_com.android.settings.pngScreenshot_2019-12-18-07-51-12-921_com.android.settings.png
smitty267
Yes dual SIM But always have had SIM cards in #1 Slot without issues..#2 has SD card
Ed404
Do you have a dual sim phone where one sim is preferred for data usage?
geopublic
@smitty267Post a screenshot of your APN
If you're phone's APN setting are switching on their own, this is a phone software issue. You'd have to take this up with the manufactuer.  Have you tried removed the other invalid APN settings?
ChuckYeah
@smitty267 What OS version are you using?
Are there two APN settings in Access point names?
ChuckYeah
Is this what you PM APN lookslike?
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
