12-23-2022
04:26 PM
12-23-2022
06:18 PM
computergeek541
When entering YES2 the circular motion is replaced by a red background with.. exclamation point. message "unable to send".
Any way to fix this problem? Dec. 31 is a week away
Add-Ons
12-23-2022 04:29 PM
HI @m121838 you might be just having problem sending text in general. Test if you can send text to friend
Anyway, for this , easy way is to just open ticket with CS agent and ask them to add it back for you, they will do it fast:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
