11-14-2023
03:31 PM
11-15-2023
01:58 AM
computergeek541
Hi there, I am having difficulty loading my PIN, I have been with Public for about 5 years and never any problems.. II am not technical. Any suggestions??
11-15-2023 01:59 AM
@BKNS27 wrote:This sounds like a PUK that could be locked by Samsung so contact Samsung Canada at 1-800-726-7864.
Samsung cannot assist with maiking payments to a Public Mobile account.
11-14-2023 05:04 PM - edited 11-14-2023 05:06 PM
Surprised you are having issues if you done this in the past. I know some voucher takes 24 hours to operate but not inputting the PIN.
Best to contact a CS_Agent by private messaging at:
They will help you out.
11-14-2023 04:13 PM
OP says London Drugs and Recharge...both of which should work right away, if added correctly.
11-14-2023 04:04 PM
hi @Chezmoi123 voucher pin? where you got the voucher from? did you wait 24 hours?
11-14-2023 04:04 PM
11-14-2023 04:01 PM - edited 11-14-2023 04:04 PM
If you are trying on app or website, you can try dialing 611 and then pay there. If you are using 611, you can try to use the app/website. If it still does not work, contact CS Agent using the link below, provide them with your voucher details and other details they may ask, they can probably do it for you since you are having trouble doing it yourself.
Make sure to monitor the envelope icon on the top right since that is where you will receive the response.
11-14-2023 03:56 PM
the message is unable to process when I put in the 12 digit code. I have done the same thing for years with out any issues..it is a samsung 12
11-14-2023 03:56 PM - edited 11-14-2023 03:57 PM
Well I'll take a stab at a guess. Is this a voucher code pin? Are you sure the amount didn't go in and your account restarted (if it was suspended)? Or are you sure you don't have the new balance in your account?
Are you using the right set of 12 digits on the voucher? It should be the one called PIN#, not voucher#.
You might also need to wait an hour to try again. Are you entering via 611 (or toll free) or the app or the web site?
Adding - lol timing 🙂
11-14-2023 03:55 PM
The 12 digit code that I purchased through RECharge as well as I went to buy top up from London Drugs, both of which I have done for years without any problem
11-14-2023 03:49 PM
What actually does your phone indicate and what make is your phone because there are several PUK.
11-14-2023 03:32 PM
Hi @Chezmoi123 which PIN are you talking about?
