PIN number
WW29
please let me know where to find my PIN number for checking voice messages, thanks.
Triguy
Which gets reset to your 10 digit phone number.
When accessing from the handset it doesn't usually need the password. You can set it to but I don't think it needs it by default.
GinYVR
@WW29You should be able to reset it on the front page of your selfserve account.. it is on the right hand side that say reset voicemail password.
