01-26-2026 02:06 PM
I transferred my phone number from rogers to PM yesterday and its still SOS. i received porting message and replied yes. since then its SOS. PLS HELP
01-26-2026 03:07 PM
Had the same issue, found a solution myself:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Resolved-No-Service-After-Port-eSIM-Alrea...
01-26-2026 02:17 PM
Its e-sim. i removed my rogers sim card after replying 'yes' to porting message. Rebooted phone and still doesnt work. In the email from PM, it says can take upto 5 business hours and its been business 5 hours now
01-26-2026 02:08 PM
hi @MH16
did you try remove your Roger sim and reboot phone and test with the PM sim ?
if same, ask PM to check both the porting and sim issue, you can submit ticket by direct message:
