03-12-2022 06:20 PM
I overpaid to top up account to change my plan and added 1GB of data that I did not need to do. Would like a refund for $15 add on and the $50 overpayment.
Thank You
03-12-2022 08:14 PM
If you see those $50 on your account, just leave them there and they will be used on next renewal. Agent might initiate refund but it will take few weeks to get it so why waste time to do that...
As for wrong add-on, ask agent for refund before you accidentally start using these 1GB.
03-12-2022 06:29 PM - edited 03-12-2022 06:29 PM
Contact the support agents.
They'll likely place excess funds in your available funds for future use.
03-12-2022 06:29 PM
Since PM is prepaid, there are usually no refunds. If you have available funds, it may be easier just to leave the funds for next month's payments. Supposedly, it takes several weeks to process refunds.
If you bought the wrong add on, customer service agent may be able to credit your account.
You will need to contact customer service agent.
Click on the chat icon on right lower corner of website. Type: bought wrong add on. Follow prompts to submit ticket for CSA help. It will take 1-2 hours for response.
