Overcharged
mdeeh
I have a subscription plan that says if I subscribe for 90 days that I will receive $5 off each bill.  I have been subscribed for more than a year and never received the $5 off on any of my payments.  Is there a way to retroactively receive these overcharge/overpayments?
2 REPLIES 2
mdeeh
@hTideGnow
Thank you for your quick response. I have submitted a ticket and will watch for a reply.
hi @mdeeh
usually the plan price is reflected with the discount already instead of an extra $5 separately,  ie, instead of $25 for 30 days, it will show $70 for 90 days.
but if you need PM to check and clarify, submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
