Overcharged?
Pete700
Switch plans and now charged $50.68, and then $45 in the same billing cycle? Why? Now just switched to the $40 plan a 40 gib, will I be charged twice? I need a refund, please help?
2 REPLIES 2
HALIMACS
@Pete700
every time you switch plans on an immediate basis it starts afresh with a full cycle charge.
All prepaid mobile suppliers do not prorate or refund partial cycles.
There are warning messages on the screen before doing this. Did you see them?
You can try your luck with the customer support agents if you missed it – they may or may not be accommodating
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
SourDude1234
Hi @Pete700
When you changed your plan, did you select "change on renewal date"?
