Outgoing not working
bvrinda
I recently upgraded my PM plan, which will become active next week.
Meanwhile I keep losing my outgoing service, is this related to plan change?
Everytime I try making a call, the message immediately displays that call has ended and number not valid. I have tried the airplane mode switch on and off, then I tried restarting my phone. Initially it worked but now it doesn't seem to work.
Could anyone help me with this please? If it is not going to resolve, I will have to change my service from tomorrow. I don't want to pay for a service that doesn't work.
7 REPLIES 7
@bvrinda   PM networks uses Telus and Bell towers
However, on your phone's network selection, you should only choose Public Mobile.  There are times that choosing Telus would work too but I suggest you just try it , and if it does not work, you should change it back to Public Mobile
So, you enabled VoLTE and tested?  does it work?
bvrinda
Does public mobile run on telus or bell or is it both the same?
@bvrinda
Try to enable VoLTE and see if it helps
iPhone: Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Pixel Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
If that does not help, open ticket with PM support and have them to confirm on the system if any account issue or outage:
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
bvrinda
tried all of these above mentioned things, if it is a network outage in the area, is there a solution?
Meow
Nothing to do with your plan change.
It could be minor service outage in your area.
How about SMS/Internet? Do you have those services without issues?
hairbag1
@bvrinda
perhaps a local network problem...can you move around to test. Maybe go to other side of town. Let us know.
@bvrinda should have nothing to do with the scheduled plan change
try to make calls by putting 1 i front of the 10 digits
