05-22-2022 01:18 PM
Anyone else getting the message "Not registered on network" message when trying to make a call?
This is happening on all our phones here, 3 of them.
Service
05-22-2022 02:36 PM
@Shemp which area you are at? there is another post today wonder if the other person in your area
05-22-2022 02:35 PM
They happen every now and then but usually get resolved relatively quickly, hopefully that is the case for you!
05-22-2022 01:31 PM
Thanks, it is an outage with Telus.
05-22-2022 01:29 PM - edited 05-22-2022 01:31 PM
If it was just one phone, I would suggest to try to:
- restart your phone
- toggle into and out of airplane mode
- remove and reinsert SIM card
- try SIM into another phone
But 3...does sound like an outage if you are experiencing this on 3 phones. Are all Public Mobile providers?
Care to share the general area problem?
Or, check here:
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
edit...by the off chance these 3 renew on the same day (today perhaps), can you log into self serve and confirm statuses all say ACTIVE?
05-22-2022 01:22 PM
You can check for outages here:
https://www.telus.com/en/nt/outages?linktype=ge-footer
Not all (minor) outages are reported, though.
