Out of country
07-02-2022 01:18 PM
I’m trying to top up with a couture and it’s not being accepted online I’m out of country so *611 isn’t working
Payment
07-03-2022 12:56 AM
@Community_QA wrote:
*611 in fact can be called from US without roaming
Makes sense.....
07-03-2022 12:36 AM
Most likely on hold for several hours up to a day then.. Have you hit the 24 hours and tried again?
07-02-2022 10:49 PM
07-02-2022 10:42 PM
If you can call a Canadian toll-free number from where you are then you could also call 1-855-4pu-blic to redeem your stylish voucher.
07-02-2022 10:25 PM
@CountyDownIeUk what are you going on about *611
07-02-2022 10:12 PM
@MrSpock wrote:@Zsomuah hi sometimes it takes up to 24 hours for a voucher to activate , you can contact a cs agent explain your problem they will input it for you Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
WHAAAAAAT. Read what @Zsomuah said...is out of country.......and that means *611 won’t work unless has a USA add on and is in USA.
The answer would be.......top by logging into My Account.
07-02-2022 01:21 PM - edited 07-02-2022 01:30 PM
@Zsomuah try a different browser, or use incognito mode.
still fails, open ticket to ask PM Support to check and load it for you
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-02-2022 01:21 PM
