Other
Grace24
Can I transfer calls to another phone number?
Grace24
Ok, I’ll try that to see if it will work.  Thank you so much!
Hi @Grace24
See, I have an idea IF you were still here but if you're already out of the country, no dice and you won't be able to forward. I have ONE idea, and in theory this SHOULD work. If you pick up a data only SIM card, https://www.airalo.com/ you could download the TextNow app. Pick a local number to where you live in Canada. Then, use it to call your cell number back home, go into your voicemail settings and change your voicemail to...  Hello, this is "blank". I'm currently out of the country but I can be reached at....  ". It would be like a local call to them and you'd get called on that TextNow number. Make sense?
Grace24
Hello, to clarify what I meant..when someone calls my number, I want that call to go to another phone number.  Because I’m out of the country, roaming is not available in the country that I am now.  So the calls on my phone, I want to transfer to my sister’s number so I am not missing any calls.  Is that possible?
Chalupa_Batman
Hi @Grace24
If I understand your question, you want to transfer your calls to another phone number. Now, are we talking about you want calls that come to your phone number to be automatically sent to another number or if someone calls you and you want to transfer the call itself to another number? Just a little more details please.
@softech wrote:
@Grace24 you can use Unconditional forwarding to forwards all calls to your other number
Although there are Unconditional forwarding features, but those have not been working for couple months.
This is so confusing!!!
First you are saying 'you can use Unconditional forwarding'
Then you deny that with: 'Although there are Unconditional forwarding features, but those have not been working for couple months. '
So make your mind: ARE there forwarding features or not? Unconditional.
