Order SIM card
ererere
Is your website down?
Got message,
This site can’t be reached
store.publicmobile.ca’s server DNS address could not be found.
Try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
Try again later. May be tonight and with different browser. Looks like many are trying at the exact same time.
TroyDaBes
It might be getting hammered because of large traffic.
sm2016
1) check if other websites are working
2) try a different browser
3) restart your computer or network connection or both
4) try again in an hour
The issue can happen for a variety of reasons.. some that are in your control and some that are not
daredogg
Try again... just went to it through website, and it worked... changes address to: https://store.publicmobile.ca/cart
I had an issue earlier with website not resolving, but it turned out to be my browser needed its cache cleared. To determine if this is same issue, try an alternate browser?
