12-02-2022 08:17 PM
If I opt out of the new rewards program, will I lose my credits earned during that program, and when going back to old program, will I get back my monthly reward earnings every month that I used to have(refer a friend, loyalty,autopay)Thanks.
12-02-2022 08:45 PM
There is no way to go back to the old rewrds program so you might as well stay on the new one.
12-02-2022 08:45 PM
You should not have moved to public rewards system, because you CAN'T GO BACK. It is impossible now, so tough luck. Now if you opt out of the new rewards program, you will lose those as well, and you will not get any rewards. So it is better then nothing if you stay on the new rewards program or else you are really losing out.
12-02-2022 08:21 PM
If you are on old Rewards...Don't opt out...you can't come back if you do.
12-02-2022 08:19 PM
@tanyar21 the old rewards program is no longer accepting "entry"
opt-out of the new does not mean you are back to old. Opt-out of the new one means you give up all the credit earn on the new one and NOT JOINING any rewards program
Again, there is no way to get back to the old rewards program
