07-16-2019 08:37 PM - edited 01-05-2022 05:55 AM
07-16-2019 10:41 PM
@Annick_BI know you are new and are trying to help.. but the OP has 500Mb + 500Mb displayed on the front profile.. only users who has registered for autopay will get the +500Mb part.
07-16-2019 10:36 PM
Hello,
Have you registered yourself for Auto Pay on your Public Mobile Account?
Thanks,
Annick
07-16-2019 10:06 PM
@123egg wrote:I was capped when I hit 500mb usage when my plan clearly says I have 500+500mb because I use autopay on the $25 plan. Why does this happen and how can I get the 500mb bonus back? Thanks
How long have you had this plan? If you can get a picture of your account overview page with personal info removed we may be able to figure it out for you
07-16-2019 09:17 PM
I have the same plan and I don’t have any issues with data. Did you put a cap at 500 mb data usage at the device level or ur auto payment is not setup. Please double check.
07-16-2019 09:11 PM
@123egg Make sure AutoPay is enabled on your account. When you signin to your account you should be able to see 1024 MB for your data counter if it only shows 500MB and you have AutoPay enbled you need to notify the moderator team.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-16-2019 08:59 PM
If that shows on your overview page, that means you should have 1 GB data available.
Is your phone set up to maximum of 500 mb data use? Maybe check your phone setting...
07-16-2019 08:54 PM
It says 500MB + 500MB at 3G Speed
07-16-2019 08:44 PM
