11-17-2022 12:15 PM
11-17-2022 07:16 PM
@mulderrebel wrote:How do I talk agent
Customer support agents are contacted by opening a ticket in the chatbot. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
11-17-2022 04:23 PM
How do I talk agent
11-17-2022 01:30 PM
Maybe it is your luck or computer equipment? It works EVERY time I try to log in.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
11-17-2022 12:36 PM
@mulderrebel wrote:They changed my email yes and change the password then I create a new one it worked the first time but the second time is not working
They changed a new one and you created a new one?
if they have changed the email address used on My Account and you cannot log in with the new one, you have to go back to support and have them sort it out
Not sure what you meant by "created a new one". You cannot create a new My Account without new activation.
11-17-2022 12:29 PM
Did you use the reset password or when you were logged in that first time did you change it there in your profile?
Did you do all this in private mode? Do you get the SMS or email for the last verification or did you turn that option off in the account?
11-17-2022 12:28 PM
Yes and new browser too
11-17-2022 12:23 PM
11-17-2022 12:20 PM
What do you mean "second time"? Did you ask support to change anything? Are you using autofill or straight typing?
11-17-2022 12:19 PM
@mulderrebel wrote:It say wrong emial and password but the agent said it not the wrong email and password
@mulderrebel you got the same problem with Incognito mode?
if so, try once again using another browser (may also need to use another browser + Incognito mode there)
11-17-2022 12:18 PM
11-17-2022 12:17 PM
@mulderrebel could be browser cache issue.
Can you try to login again using Incognito mode? If still does not work, let us know what error you got
