One digit required to prevent robo calls
WD27
Does Public Pobile have a function that can be turned on to require the caller to press a button for call to go through, this preventing robo calls ?
Meow
No. No extra features at PM. just plan phone/sms and data.
No WIFI calling, no blocking spam calls, nothing.
Sansan
@WD27  No they don't.
I used that Call Protect feature at Koodo and it worked for 3-4 days only. Then it stopped for no reason.
  When I contacted Koodo, they couldn't figure out why it stopped.🤔
slusagm
that is Call Protect. The feature only available with Koodo or Telus.  PM is a no frills service provider and only provide basic services, no fancy features like that
TheSterlinger
@WD27  no they do not. You have to block numbers yourself in your phone settings.
Koodo has this feature.
