Old PM SIM card in new phone, can’t call
BPD
I put PM SIM card from old iPhone 8 to newly setup iPhone 13.  Can’t complete a phone call because PM thinks / says I don’t have available minutes, which is not the case.  I have a paid up monthly plan of 15Gb and ULCW calling (unlimited Canada wide calling).  What can I do to fix this situation?
BPD
Thank you.  That worked.
hi @BPD can you confirm if data works and if you can receive calls?
can you test you sim back in the old phone?
try Reboot your new phone with the PM sim and try Reset Network Settings after
Chalupa_Batman
Hello @BPD
One, try rebooting the new phone. Two, go into your settings, find Network Settings, refresh Network Settings and then reboot. You should be OK then.
If you're still having troubles, you can create a ticket and find out why you keep getting that error.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
EDIT: Question, where did you get the iPhone 13? Is it a Canadian version or overseas version?
