Old Number on Sim Card
Ingme
Just ported in this morning and all is working except the sim card is still displaying the temporary old number in the settings and not the new ported number. I tried resetting the Pixel phone and removing the sim card. Will it change on it's own or is there something else to try?
Ingme2
Update: After trying phone reset, mobile network reset and waiting, the problem was resolved by contacting CS as they said there  was an error in the account
Ingme
Yes, I only have the sim card and one disabled e-sim from a deactivated account.
Does any info have to be added when you do a mobile network reset or does that get automatically added from the service?
hi @Ingme
can you confirm if inbound calls to your ported number is going to the PM sim ?
if so, it is ok, the phone number will eventually change.  Try Reset network settings after couple days
if you are using eSIM, you can wait a month and rebuy a new eSIM and it will correct it
