06-19-2023 01:29 PM
Hi recently switched from Lucky Mobile to Public Mobile.
I requested to transfer my phone number and it worked and I had access to sms messages, phone calls, and voicemail.
When I restarted my phone, my eSim stopped sending sms messages, phone calls, and when I request a new voicemail password, it doesn’t work when I reset my password.
I bought a SIM card today to see if it would fix issue but didn’t.
06-19-2023 01:46 PM
Hi there, double checked and yes, it’s changed to new physical sim.
06-19-2023 01:44 PM
A week… it stopped working maybe 3 days ago
06-19-2023 01:43 PM
@amandinette wrote:Yes I received sms and phone calls on public mobile eSIM card after transferring phone number.
it was an eSim but I bought a new physical SIM card and changed the eSim number in my settings to physical SIM card and restarted my phone. Didn’t work
@amandinette so you went through this?
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
Can you go back and check again to see if the sim card number now showing the physical sim?
if the physical sim card number is there, then likely just a sim card provisioning issue, open ticket with support as advised above.
Also, test the sim in another phone, just in case it is a device problem
06-19-2023 01:40 PM - edited 06-19-2023 01:42 PM
06-19-2023 01:32 PM
@amandinette - did you already delete the eSIM? IF so, I don't think you can get it back...?
In any case, see if CSA can help. The 2 ways to contact the Public Mobile Customer Support Agent (CSA)_Team are below:
1 - Normally Faster - use this link to: Get Help With Public Mobile Chatbot], OR
2 – Slower - Use this link to: Contact Public Mobile Representatives (CSA) by submitting a PRIVATE MESSAGE to start a ticket to them here: Private Message to Public Mobile Customer Support Agents (CSA)
06-19-2023 01:32 PM - edited 06-19-2023 01:32 PM
@amandinette you sure the porting was completed earlier?
If you receive incoming calls and text on your PM sim after activation, then yes, the porting was done
and for the phsyical sim card, did you login to My Account , Profile Page and update the sim card there using a computer (laptop or desktop) and not using mobile device? The part of the site have some glitch and need to be done on a computer
And what sim card number showing there on My Account's Profile page? is it the physical sim card?
I would open ticket with PM support and ask them to reprovision the sim card, please message them
