OVER CHARGED
Granny60
Payed my bill and you took 3 payments out . Not happy at all . And you make it impossible to talk to anyone to get it fixed
2 REPLIES 2
Meow
Highly unlikely such error will occur.
Do you see those charges on your credit card and/or your PM account?
hi @Granny60
the overpayment amount should be showing on the Available funds and ccan be used for next renewal
but if you like to have PM to check the issue, submit them a ticket
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
