Number
Rupi
Hi I want to refer one of my friends with my code but when I login I cannot find my code. Can you tell me step by step where to look for the friend referral code? Thanks
SourDude1234
It should be at the bottom of this message in the same color as "sharing is"
SourDude1234
This exact same question was asked yesterday in this same forum.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Help-with-code/td-p/1083975
Please try looking there (and any other prior posts by using the search bar at the top) first. Most of the time, your question will be answered straight away. If it has not been answered, then you can seek help.
Hello??? I'm just a volunteer fellow customer here. Ease up on the demanding.
When you log in to the account you will see a whole area near the top with a heading saying Sharing is caring. If you see Public Mobile in your pocket then click the little circle underneath to go to a different slide. There are only 2 slides. Lower down in that area you will see your referral code in the link thing.
Rupi
Hello???
Rupi
Can you send a picture of it I cannot find it
dust2dust
Upper area of the account page. It's called Sharing is caring.
