Help with code
Gurleen228
Hi I need some help. I want to refer my the code that you get 1 dollar off but I can’t find my code can you help me find it. Thanks
12 REPLIES 12
Abheer
Hi @Gurleen228
Just checking in, have you been able to resolve this issue or do you require further assistance?
Phil_Adelphus
@Gurleen228 wrote "I am not sure which account I used for it or the username for it. could you help me find that?"
Do you want to give someone your code so they get $10 off and you get $1/1 point?  As far as I know it should be one referral code per account, so if you have several accounts you could use the code from any one of them.  Are you not able to log in to any of your accounts?   Or is it that you already referred someone and you want to see which of your accounts got the $1/1 point because you don't remember which one's code you used?
Abheer
Yes, but below it should say "Forgot email" I will attach image below.
Forgot email, not forgot password.
Gurleen228
When I do it it only says email address no where I can add my phone number. can you show me step by step
Abheer
Just enter your phone #, look through all email addresses until you find the account.
In the login screen. Lower down. Says Forgot email.
Gurleen228
how can you do the phone number thing??
??? What do you mean which account you used?
You can try to find the email login id by using the forgot email link. Then enter the phone number of the account you want. Then look in any and all email accounts you can think of to find the email address.
Gurleen228
dust2dust
Log in to your account, in the upper area, it's called sharing is caring. You will get the $1 if you're on the old rewards system. You will get a point if you're on the new points system.
Abheer
Hi @Gurleen228
You can find your code by logging in to your self serve account. The link and the code should be there.
