Number transfer
Papamarko
It's been 48 hours since I requested a number transfer from Virgin to PM, nothing yet, it said it could take up to 5 hours, what's happening?
@members
2 REPLIES 2
hairbag1
@Papamarko
did you receive the text that they send confirming your intent to transfer your number to Public Mobile...to which you must reply yes within 90 mins ? If yes, then try removing the Virgin sim and installing the new Public Mobile sim. If using esim, disable Virgin esim and make sure Public Mobile esim is primary.
@Papamarko
Did you remove the old provider sim card , or disable the old esim? Reboot the phone with the only PM sim there and try incoming and outgoing calls
And there is a number to call to talk to live support,  they can provide you and update.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
