Transfer number from Telus not complete
BlaineCockell
Teleus has not acted on request from Public to cancel account
@Ash33 @BlaineCockell
Dont ask Telus to cancel account.  If account with old provider is not closed, it is because the port was not done.  Closing the account earlier would stop the port request and number would be lost
@BlaineCockell proper way is to check with PM and confirm if account is portedband check what was wrong
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
Ash33
I would call Telus main phone number directly,  explain the situation, and have someone help you through the phone.
The link  to get in contact with Public Mobile support is here if you want it:
hi@BlaineCockell
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
Chalupa_Batman
Sounds like your porting request didn’t work.
There are two options. There is a number you can call that is primarily used for Koodo and Telus but some have had success using it with Public Mobile porting issues. Please go to your inbox using this link to see the number as they don’t allow the number to be posted on the forums.
Alternatively, and according to Public Mobile CS Agents, since Public Mobile is a self serve service, they prefer you create a ticket. Here is a direct link on how to contact a CS Agent.
