3 weeks ago
we have 2 phone numbers using the same account. how do we make a payment on the 2nd phone number using the same credit card?
3 weeks ago - last edited 3 weeks ago
You can also dial 611 from the phone that you wish to make the payment on.
From there, follow the prompts to add a payment if you know the four digit PIN in which to do so for that number.
I've never actually done this, but I believe I'm explaining that correctly.
Let me know if it works for you!
https://www.publicmobile.ca/en/get-help/articles/managing-your-account-with-611
You CANNOT have one account with 2 phone numbers.
Each number is associated with only one - independent account.
And each account can be paid with the same credit card. Enter CC# into each account and you are set to go...
3 weeks ago
hi @sherryfsmc if you have2 numbers, then you must have setup 2 accounts as PM system is setup with single number in each account
so, you need P agent to help to retrieve the login for the second account. you can submit ticket by direct message:
but if your plan has already expired or you need to pay it very soon and don't want to wait, then buy a voucher from Shoppers drug mart or Loblaws or No Frills and then load the voucher using *611 or My Account
This is the full list of retails that you can buy vouchers. Vouchers in some stores need to wait 24 hours, but vouchers from Shoppers and Loblaws can be redeemed immediately:
https://www.publicmobile.ca/en/payment-voucher
On top of physical stores, you can also buy online with extra service fess: buy from muskbird.com , ding.com , recharge.com
3 weeks ago
PM system is designed for one account for one number. You have 2 accounts, so you must use a 2nd email to set-up a 2nd account. So, look like the 2nd account was not setup properly with an email. You need to ask PM to sort it out. You will need to message them here:
