04-26-2022 08:02 AM - last edited on 04-26-2022 08:07 AM by computergeek541
I have set up my account and credit card. How is my cell number transferred from my old provider? I’ve set up the account yesterday.
04-26-2022 07:20 PM
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If you are having issues with a stuck or incomplete port, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
04-26-2022 06:10 PM
You will need the account number from previous provider as well..If you need help getting it let me know
04-26-2022 10:51 AM
Where are you porting the number from and was it a prepaid or postpaid account?
04-26-2022 09:13 AM
You personally have to initiate porting (transfer) of old number.
Make sure ALL services work well with PM before you initiate porting.
04-26-2022 08:11 AM - edited 04-26-2022 09:11 AM
@142452 Did you request number transfer (porting) when you activated your PM account? or did you just pick a new number and would like to transfer your old number now?
If you have a new number now and would like to make the transfer, login to My Account and Pick Change Number, then select Transfer a wireless or wireless number from another provider there and follow the steps
If you requested porting already when you activated, let us know, there is a team you can contact for update
04-26-2022 08:11 AM
If you chose to port the number during the activation, did you respond YES to the port authorization text that you would’ve received if you kept your old providers SIM card in your device?
If so, try rebooting your device and resetting network connections. If you did not get the port authorization text, contact customer support by clicking Chatbot (SIMon) at bottom of page. https://www.publicmobile.ca/en/on/get-help
04-26-2022 08:04 AM - edited 04-26-2022 08:05 AM
Log into your self-serve account and go under the change number section in the “My Profile” section to the right.
Under that you will see an option to transfer number from another provider.
Your old providers service will need to be active to transfer the number.
