03-22-2023 12:18 PM
My number was supposed to have been ported within 30 mins. Its 10hrs later and still not ported. I use my phone for business so none of my clients can get hold of me.
03-22-2023 01:19 PM
Are you porting out of PM? It shows that you are on this Community since December 3/21.
If you are porting out then you need to contact the new carrier.
03-22-2023 12:28 PM
yes.
03-22-2023 12:23 PM
It was active and working
03-22-2023 12:22 PM
Is your old account still active and working? Was it active at the time of porting? Was it close to expiring?
03-22-2023 12:21 PM
Yes.
03-22-2023 12:19 PM
Did you get and reply to the confirmation text on the old sim?
03-22-2023 12:19 PM
Did reply yes to the text within 90 minutes with your old sim card still installed?
