12-06-2022 09:01 AM - edited 12-06-2022 09:03 AM
12-06-2022 09:40 AM
HI @agladushko are you trying to port in your number?
if you are , you can login to My Account and then request Change phone number there
if you are porting out, then you will have to get your account number from My Account and give the account number to your new carrier and they will arrange
12-06-2022 09:18 AM
Do you port in on out of PM?
You have to initiate porting and leave old (current) SIM in your phone. Reply Yes within 90 minutes of transfer authorization SMS request.
12-06-2022 09:18 AM
If you're porting out, follow the instructions from your new provider, making sure your public mobile account is active and you retain the same card in it.
If you're porting here, do the same. If you are having problems porting, click the following link to reinitiate the port:
https://urlshortner.tiia.ai/Lc9xk8
If you continue to have porting issues coming here, check the phone number I will send to you via private message. To check your private messages click the envelope icon upper right.
12-06-2022 09:18 AM
@agladushko you have made your request yet?
are you porting in the number or porting out of PM?
give us more information and we can try to help
12-06-2022 09:05 AM - edited 12-06-2022 09:06 AM
The community forum isn't how you request to port a number. If you are coming to PM you can do it via your account. If you are leaving PM, you can have your new carrier put in the request. Porting sometimes can take a bit of time, and you will have to respond to the text that comes to you confirming you wish to port so keep your old SIM in until that time..
