Number port question
bgrewal87
Hello
I am wondering if it is possible for a friend from  wind mobile, to port her number and take over my account with her number. I am on the $120 / 12 gig plan. Is it possible for her to port her number and keep my plan?
2 REPLIES 2
zhadj030
@mimmo posted Seconds before I do, So I basically repeated what he said but I was screaming in the process.
For that to happen YOU WILL LOSE YOUR NUMBER IN THE PROCESS. So yes she can port her number to your account and take the promo but you will end up loosing your number
mimmo
yes it is possible, but you would lose your number.
people can either\
  • keep their plan and lose number (port a number in)
  • keep their number and lose the plan (port your number out)
for your friend to take over you account you simply loginto selfserve and select chnage number, you ten remove our dredit card info and your friend chnes teh email and password to self serve.
