12-01-2022 02:53 PM
I activated my public mobile account. My phone says sos. It’s been 3plus hours with no phone. Help please
12-01-2022 11:21 PM
Yes I did! The administration has it figured out! Thanks for the suggestion 😊
12-01-2022 06:46 PM
did you reply 'yes' to the port authentication request from your previous provider?
12-01-2022 04:03 PM
Hi,
I tried the sim in another phone and it did not work. SOS displayed. My phone shows under physical sim that the carrier is public mobile but network is not accessible.
12-01-2022 02:56 PM
Thanks. I’ll give it a shot!
12-01-2022 02:54 PM
@Cleo2 If you phone shows SOS, it could be a sim provisioning issue , which is different from porting
did you try to reseat your sim card?
do you have another phone to test the PM sim card?
Please open a ticket with PM Support and ask them to check if sim card was provisioned properly
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
