10-22-2019 10:21 AM - edited 01-05-2022 07:41 AM
10-22-2019 06:28 PM
@985ryan wrote:
This was new number issued to me, not ported from another carrier. Again, its random. When i call with my other phone sometimes i get voicemail, other times i get not in service.
There isn't anything you can do from yiur end to fix (or cause) your number to go into not in service status (other than letting you plan close from being suspended for 90 days). This sounds like an account provioning problem.
10-22-2019 11:36 AM
It's strange incoming calls are received but can't make any calls. Best to get a moderator to correct the issue. Send a ticket by clicking on ?, bottom right, and following instructions.
10-22-2019 11:25 AM
@985ryan wrote:when i click question mark on bottom left of screen i get box to type questions, but no specific way to submit ticket.
It works fine for outbound.
To submit a ticket to Public Mobile do the following:
10-22-2019 10:59 AM
Try sending a message to a moderator.
Moderator can be reached at
10-22-2019 10:57 AM
10-22-2019 10:34 AM
@985ryanWhat plan are you on? Can you log into your selfserve just to double check on the status of your plan?
10-22-2019 10:28 AM
Did you port (transfer) your phone number to PM ? If so then you would need to submit a ticket to a moderator by clicking on the question mark on the bottom right.
