03-14-2019 09:20 AM - edited 01-05-2022 03:42 AM
Hi all,
New member here. Here's my story.
I'm a new member (March 13), everything was working great, so i decided to port my number over from Telus. It said everything was sucessful when i performed the port via self-serve. . Since then, i can't call or send text messages.
When i look up my profile on Public Mobile, it lists my number correctly. If i call that number from another phone, i don't get my voice mail, i get a message saying that the number isn't in service.
I paid off the remainder of my telus account earlier today, but i still can't get the phone to work. It was on a corporate plan, not sure if that matters.
Any suggestions?
Thanks in advance!
03-14-2019 10:18 AM
@gallant684 wrote:Unfortunately, it didn't work for me. But a mod replied to me already, so hopefully i'm on the path to a solution.
Thanks again everyone! I'm not used to getting service this way, a bit of a learning curve! 🙂
Keep trying..it will come easier!![]()
03-14-2019 10:05 AM
@gallant684 You won't loose your number, it just might take a little longer to get it working ![]()
03-14-2019 09:51 AM
03-14-2019 09:41 AM - edited 03-14-2019 09:42 AM
Thanks @Alex888
I actually did so i'm just waiting to hear back from them.
I was worried that i might end up losing my number, which i really hope doesn't happen.
EDIT Thanks all! I'll give it a shot.
03-14-2019 09:34 AM
@gallant684 try doing the lost phone/found phone option in the self serve, rebooting the phone on each step,If didn’t work, You need moderator to work on your port. Send a private message to moderator.
03-14-2019 09:29 AM
Yes, contact moderator as described above. It might be an issue with the corporate account. In the past, some people had to switch from corporate account to regular consumer account before porting. Not certain if that is the procedure now.
You could also try the lost/stolen trick. Sometimes this helps to reset plan.
To report your phone stolen. Login to your account. Choose Plans and Add-ons tab. Then choose Lost/Stolen Phone tab. The choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found.
03-14-2019 09:26 AM
@gallant684 It sounds like an incomplete port, you will need to contact a moderator. You can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
