12-02-2024 08:38 PM - last edited on 12-03-2024 08:11 AM by computergeek541
12-03-2024 12:07 AM
hi @Nameet so, is there any Public Mobile eSIM on the Settings-> cellular scree?
or you still see other sim there?
12-03-2024 12:04 AM
Activating esim. No physical SIM
12-02-2024 11:59 PM
hi @Nameet are you activating eSIM or physical sim?
and you removed your old carrier sim card yet?
12-02-2024 11:43 PM
@Nameet Can you toggle on “turn on this line “ assuming your trying to activate eSIM with public mobile ? Or you have physical sim for public mobile ? If physical put it in the phone and reboot the device and test
12-02-2024 11:42 PM
Yes i gave esim number of this device.
12-02-2024 11:40 PM
I have iphone 11, the screenshot you sent is not matching that
12-02-2024 11:35 PM
@Nameet are you using eSIM for public mobile sim? If so make sure your PM eSIM is enabled /set to primary if iPhone make sure you toggle on “ turn on this line and reset network settings
Toggle on “turn on this line”
And finale old carriers sim or remove it if physical sim and test again
12-02-2024 11:32 PM
Yes, I ported a number and said yes to porting consent however the network is still showing my old carrier and not pubMob
12-02-2024 08:46 PM
to start a new PM account you must first download the PM app to your cellphone, then start the activation process. Are you trying to port your number in to your new account ?
12-02-2024 08:45 PM
@Nameet Are you using the app to activate ? You need the app not website to activate , but if your using the app and already paid and it’s not working get support to help you
