Number Transfer Failed
Rizwan123
I chose to transfer my number to PM while activating. I received a message from Koodo asking me to approve the transfer by replying Yes, which I did. However, the activation on PM failed. Now my Koodo service has stopped working, and PM is active on a new temporary number. I have already raised a support ticket. Is there anything else I should do? @CS_Agent
18 REPLIES 18
PatrickBateman
Much appreciated 🙏
hi @PatrickBateman
 I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
PatrickBateman
May I also have the number?
@Sergio_Cheung wrote:
I suggest you to wait for the online agent from PM, they will solve your issues in just a few minutes
This isn't how customer service at Public Mobile works.  Customers almost always need to contact Public Mobile's customer support agents first.  Simply waiting doesn't usuaslly work, nor does tagging CS_Agent.  A ticket would need to be opened.
Sergio_Cheung
hi @armackin
Sent to your community inbox
please remember that number is only for checking porting status and not for other support issue
armackin
Can you please message me the number as well? My number failed to port from Rogers to PM. Thanks
@Sergio_Cheung of course.  Sent
Sergio_Cheung
Can I have the porting assistance team contact please?
Foz88
@IJA2026 , I have PMed you the number.
IJA2026
Can I get the number as well, same thing.
Foz88
I'm having the same issue. It's been 16+hrs. I've tried calling the number that I found for porting issue but was unsuccessful in getting assistance as it asks for the number that was ported and says it doesn't exist. The call then forwards you to Koodo customer service but it requires a Koodo prepaid account to verify for callback. I was with Koodo postpaid so cannot log in to a prepaid verification. How does one speak to an agent for this porting failure issue? I've opened a ticket yesterday and haven't recieved a reply.
Thanks
gargshobhit07
Yes but it is failing
Karan7777
Do you try to activate esim?
gargshobhit07
Can you please send me the number also. I am also facing same issue
Yes @Karan7777  , porting team can help. I have sent you the number
Karan7777
Can i get the number, i also have tge same issue
slusagm
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
