Note 8 needing an esim, Help please,!
lamberguini
I consider myself a pretty tech savvy female, and either I'm just halt cooked or the website is glitching out @ the page it says, click on the "Get an eSIM here" button .. I don't have any previous experience with e-sims and I just want my phone working again! Every store in my town says they "no longer make or carry PM sim cards" and the store I regularly buy them at is some "quick'E'mart" and he doesn't know where half his stock is EVER which is frustrating AF. And I don't think I mentioned the phone boots up and it's a verizon phone.. anyways if anybody has any insight please do tell!
Much  ♡ , £ambo.
2 REPLIES 2
@lamberguini  Note 8 DOES NOT have eSIM support
For Samsung, Note 20 was the first one with build-in eSIM
For physical sim card, get it from Amazon for faster deliver if you cannot get it from local store, of course, you can also get it from PM online
@lamberguini  eSIM  is only for new activations . You can download it during the activation process . If your existing customer then sorry physical SIM card is your only option . Call around to locol Telus koodo store for availability . Or order from Amazon
Adding are you sure the note 8 even supports eSIM ? @lamberguini  I don’t think it does . You may have no choice but a physical SIM card
