04-18-2026 05:35 PM
I have auto pay set up. A payment was made yesterday but since yesterday late afternoon my phone just says not registered on network
04-18-2026 05:42 PM
Check your account to confirm it is still active and when it was next pay date.
if you pave physical SIM pull it out of a minute/two and insert it back.
Do hard phone reboot (turn off/wait/turn on).
Confirm who is service provider checking settings in your phone.
04-18-2026 05:41 PM
did you try restarting your cell ? Also try network re-set if that doesn't help.
04-18-2026 05:41 PM
hi @RoselleD
try Reboot the phone and click Reset network settings
if that does not works, try to take and sim card out for a minute and put it back firmly and test again
if same, ask PM agent to help , submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
