Not registered on network
Curtis2552
I just activated my new physical sim. But can't make calls, always says not registered on network
2 REPLIES 2
Curtis2552
IT WORKED! Thanks for the tips.
@Curtis2552
Did you port your number over from another carrier or did you pick a new number?
Reset the Network setting on your phone and reboot your phone and see if that helps.
