03-27-2024 10:38 PM - last edited on 03-28-2024 12:05 AM by computergeek541
Late last week I switched from Roger's to public mobile. Since switching, I have not been able to recieve text messages from Roger's customers. The Roger's customers recieve my text messages, but I dont recieve their replies. I have switched the sim card into my old phone, but the problem still persists.
03-27-2024 10:54 PM
Thank you. The Roger's sim no longer works. If you could provide the contact information, that would be great.
03-27-2024 10:51 PM
So then my suggestion is to place the PM SIM card into a different phone and reboot it. If that works, it basically reprovisioned the card properly and can then be placed back into your phone... after rebooting it of course.
03-27-2024 10:47 PM
Thank you. I just put the Roger's sim back in the phone and it is indicating "unregistered sim".
03-27-2024 10:44 PM
@SMI97 - Does your Rogers SIM work? If you do not have it anymore, try logging into your Rogers account and if it works go here for the porting team number: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
If not, please click the little chat bubble in bottom right corner and type in "Get an Agent" to send a ticket to CS_Agent.
03-27-2024 10:43 PM
@SMI97 When you ported number from Roger’s do you leave the Roger’s sim in the phone to reply YES to the confirmation text to port . Dose your Roger’s sim still work ? If it does then the port hasn’t completed . I will send you private message with listing team number . They can re trigger the port request for you
03-27-2024 10:42 PM - edited 03-27-2024 10:42 PM
Hey @SMI97
If you place your Rogers SIM card into your phone, do you still have service? If so, I can send you number to call tomorrow to have that fixed up. Let me know first....
Also, have you tried placing your PM SIM card into another phone and rebooting it then seeing if that works?
