04-07-2024 07:35 PM
Just ported over from bell this morning. Using iPhone 13, calls are fine
Texts are not coming in. Seem to be sending with bell SIM card still inserted.
Help
04-07-2024 09:01 PM
Switched from VM to PM too yesterday and having issues with texts and iMessages. It’s really frustrating.
04-07-2024 08:48 PM
Chris I had the exact same issue yesterday, ported from Bell and sms and MMS didn't work. Checked my APN settings to verify, but after I opened up a ticket things started working within 12 hours.
Hope this helps
04-07-2024 07:57 PM
hi @ChrisfromPEI don't use ChatBot then, message them using this link
04-07-2024 07:55 PM
@ChrisfromPEI The very bottom link I sent should work to send private message to agents . You are already logged into community so shouldn’t need to log in again . Click it and start to type message to the agents
04-07-2024 07:42 PM
The bottom support tab won’t let me sign in. Keeps timing out. Can’t receive texts,
Not a great start to my Public Mobile experience at all.
04-07-2024 07:39 PM
@ChrisfromPEI Public mobile is struggling with new activations , best to constant support to help . Hope and pray it works . I can assure thou it’s not your phone the issues it’s a PM issues
submit ticket with support to fix . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
