Not receiving texts in time
foxonefoxone
Hi
This has been happening recently, I receive calls just fine however , I do not receive texts on time. I have full signal strength most of the time and calls are no problem. However, texts reach me fairly later , especially group texts. Sometimes mine are also not delivered.
 Would appreciate help.
Thanks
8 REPLIES 8
@foxonefoxone wrote:
Well more than an hour, more like 12 hours ish.
Its the regular SMS, the Imessage works fine.
@foxonefoxone
Are you texts Blue (iMessage) or Green (SMS) in color?
If Blue (iMessage) you need to be in WIFI areas or have Data enabled on your device to use: https://support.apple.com/en-us/HT207006
if you have a second phone around, try it for a day or two and see.
Also, group text could be an issue from the source side or from PM side..  harder to troubleshoot
foxonefoxone
@foxonefoxone
Likely an issue with RCS (for android) or iMessage (for apple).  If your data working properly? Is your data turned on all the time?  Need either wifi or working data for these messages to be sent on time.
Wow, that's an awful lot of work to do just to get the text function to work.
@foxonefoxone how late ? like an hour or more?
also, are you on iPhone or Android?
are your sure this text you got late are true SMS or they are in fact  iMessage/RCS??
Triguy
Try rebooting your phone.  Also clear your cache.
Were there any updates or changes to the phones around the time the problem was first noticed?
What messaging app are you using on the phone?
@foxonefoxone
if you have an android device go to app and do Clear Cache,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and you can try to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
for iphone  go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
or can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone
This is quick and simple,
