10-05-2022 12:54 PM
I'm not receiving texts and I think phone calls from some people. What to do?
10-05-2022 01:08 PM
@Casken66 did you request porting?
still call the number I sent you and ask the porting team if that was fully completed
The text you got from some of the friends could be iMessage or RCS message, which are not true SMS.
10-05-2022 01:04 PM
Not receiving texts from some friends. Most I am
10-05-2022 01:04 PM
@Casken66 hello there is a number you can call to restart the port request, I will pm the number to you ,check you envelope top right corner
10-05-2022 01:02 PM
@Casken66 so, no incoming calls and incoming text?
did you just join and request porting?
if so, a critical part to porting is to receive a text from your old provider and reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, maybe you didn't get the text from your old provider or you didn't reply in time?
There is a number to all to talk to live support and the can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
10-05-2022 01:02 PM
Yes
10-05-2022 12:59 PM - edited 10-05-2022 01:01 PM
