Not receiving text message
08-21-2021 03:03 PM - edited 01-06-2022 03:13 AM
08-22-2021 10:18 PM
Try sending a message to your own number. That worked for me one time when I was with Telus.
08-22-2021 10:06 PM
@johntaddeo wrote:I was trying to see if I could recieve text when out of wifi range and sent a test message to my public mobile phone and didnt recive it. I have basic $15 plan but says included international texting? Please help!
Ensure your Airplane Mode is not enabled. If it is on, turn it off.
If you are android? Disable your Chat Features:
- Open Messages
- Tap More options > Settings > Chat features
- Turn Enable chat features off
If you are Apple?
*ensure iMessage is enabled
*ensure SMS is enabled
-Turn off both wifi and mobile data.
-Log out of my apple id for the messages app.
-Reboot phone at various points in trying things, including forced restart (vol up, vol down, hold power until restarts)
-Restart messages app at various points in trying things.
08-21-2021 03:23 PM
Ensure you have the correct APN settings by visiting HERE.
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your DATA is on.
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Good Luck
08-21-2021 03:07 PM - edited 08-21-2021 05:31 PM
SMS doesn't use Wi-Fi. An error message sayiing that the message could not be sent could be the result of a incorectly formatted number. Also, try disabling.any RCS or iMessage features and ensure that SMS is enabled.
