Not receiving confirmation via text
Oremus
Can’t seem to receive the confirmation text to confirm number ported successfully.  I checked the Cellular section in Settings and the number has been ported and we are on PM.
I’ve tried to log into my Eversafe account but can only get as far as receiving a confirmation code in the email and not the second one sent via text.
I logged into my account of the previous carrier - SpeakOut Wireless and there is no number associated with my account so the number has been ported successfully.
We are able to use the data and make outgoing calls, but cannot receive texts or incoming calls.  I checked call forwarding and it’s not active.
Is there a way to receive the OTP via email or another phone number? Any advice would be greatly appreciated.
RavingRaven
@Oremus
The verification text is only sent to the primary phone # at activation. It sounds like you have a stuck port but it appears speak out has released your phone # to pm. So you may need to remove the speak out Sim card and choose the PM e-sim as your primary Sim. Then reboot your phone. See if that works while you wait for a reply from an agent.
Just in case check your private message box. I sent you the porting department and Speakout's customer service phone #'s if you need to check on the status of your port with either of them.
It could also just be a Sim card provisioning issue at activation that an agent can quickly sort out for you.
@Oremus wrote:
Subscribed on September 01.  Not sure what to do at this point.  I’d give my alternate number to confirm to receive a text but not sure whom to ask for help.  Does PM have customer service for these situations?
Please send a pirvate message to a Public Mobile customer support agent. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Oremus
Thanks for your reply.
I did restart the phone and made sure that the previous sim from SpeakOut wasn’t removed.  We are using an eSIM and that looks like it was activated properly.
It’s weird coz we can’t receive any texts or calls from anyone including TELUS/PM customers.
The OTP/2FA has never been received through text and there isn’t an option to receive it other than email first, then a text.
I did receive a reply YES to approve port to PM from SpeakOut.
The porting confirmation sent by Public Mobile is only for informational purposes and really just says to restart your phone if you already have the Public Mobile SIM card in your phone. The actual text message about this isn't something that is needed.
As for the text message from Public Mobile about a 2FA/OTP to get into your self servce account, that can usually be sent to your phone by text message during the first request.  You can try the resend code/didn't get code button to see if the option to have the code sent by e-mail is there, but I don't believe that it will be there.
When it comes to the phone number that your phone reports in the settings menu, that doesn't mean that porting was done correctly or that it has finished.  Public Mobile assigns that phone number to your account before porting has even been completed, so it your phone would show that phone number regardless.
As for not being able to receiving incoming calls and text messages, you should be able to still receive some of those if the people contact you are also Telus/Public Mobile customers.  There can be a delay of a few hours for number porting to complete.  Did you reply to a text message from Speakout and reply "YES" to approve the phone number transfer?
