Not getting incoming calls
Phil1238
I ported from Fido yesterday and am not getting incoming calls or text messages.
I am able to make calls and send text messages.
Please help!
1 REPLY 1
Dunkman
@Phil1238
That is a typical sign of the failed port.  Did you answer "yes" to Fido's confirmation port text?
I will private message you the Telus porting team number.  Number only used for porting issues. Check your private message inbox (envelop icon on upper right corner of website).
