Ring in
Robert54
Why my phone does not ring when someone calls
Robert54
Was set to silent and did not know
@Robert54
Did you block the caller?
hi @Robert54
but your phone can make outbound calls and just not inbound?
make sure you didn't set to silent or you didn't enable Silent Unknown caller options
also, try Reboot the phone and Reset network settings
and tell us what phone do you have and where you are
and you are at BC Kamloop?  there is Mobile outage there
