Sim issue
Walter4
Need help activating my sim.
7 REPLIES 7
Walter4
Thank you! I just tried those steps, but I still get that message on step 6 of 6 on the app when I login. The sim is showing on my settings as public mobile though.
e
@Edwin204 wrote:
Not sure if you were trying to activate your sim card during the same time an update today (supposedly Mar 5/24).
Trying later. I would power down your phone completely, remove the sim card, then re-insert the sim card to ensure it is seated properly. Re-attempt the activation and if you get the same error then send a message to CS_Agent. Cheers and good luck!
When support is needed, all customers should be using the chatbot or the app for to make a ticket for initital contact. Customers shouldn't be sending a private message to CS_Agent as the first step.
Edwin204
Walter4
No I haven't tried it on another phone. It is a pixel 8. When I did the assisted set up on the app at the final set up after I entered in all the info and transferring my number it said there was an error and to contact support.
@Walter4
did you try the sim on another phone?
is the PM sim connecting to PM network at all?  What issue you see so far? give us more details
Walter4
I have a pixel 8 and it is a physical sim that I have in my phone right now.
@Walter4
what phone you have? you got any error installing the esim?
[update: sorry, thought you had an esim]
