2 weeks ago
2 weeks ago
Samsung s20 is in fact not esim cocompatible. I also have this phone.
Probably quicker to purchase a physical SIM card from Amazon for $4.99 it works just a good as the 9.99 one.
Or from a Telus store if they sell them. Then you can change the SIM number under your profile when you have it or ask agent to do it for you.
2 weeks ago
hi @hifromweed you with CS agent and confirm , but there is a chance they will ask you to change back to physical sim ,
you can submit by direct message:
