Not able to make phone calls
Nick1111
Always “call failed”
2 REPLIES 2
@Nick1111
does incoming call work?
Try ,
  • first try to reboot the phone
  • If that does not work, change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
  • Try to click Reset All Networks and see if it helps
  • and do you have another phone to test the PM sim ? just to make sure it is not a device problem.  Also, that can force a sim card re-provision and it could resolve the problem
  • Also, try the phone in another area if possible, it could be just a local network outage
dust2dust
Are you on the $15 plan? Can you try adding a 1 in front of the phone number if not there.
