04-14-2020 01:03 PM - edited 01-05-2022 10:21 AM
Hi everyone,
I tried the compatibility tool with no luck.
just wondering if Nokia 8 and Samsung J3 can be used on Public mobile?
thanks in advance
04-14-2020 01:12 PM - edited 04-14-2020 01:12 PM
@Perryb My Samsung J1 works perfectly with PM, so J3 should to.
04-14-2020 01:09 PM
They should be compatible as long as they are unlocked and North American version.
Public Mobile uses the following frequency bands:
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
04-14-2020 01:09 PM
@will13am wrote:@Perryb , both phone are compatible with this service. Please use the information on this wiki for compatible bands on the network.
https://en.wikipedia.org/wiki/Telus_Mobility
This link you put up here is super helpful to know, it would be nice if PM just had that on their web page. If the tool they provide is not accurate, that's not helpful.
04-14-2020 01:07 PM
@Perryb wrote:Hi everyone,
thanks in advance
Looking through the List it looks like your Samsung Galaxy J3 is compatible as you can see from the screenshot below. I could not find the Nokia 8.
You can go to the get started screen and look at the list to see if your phone is compatible.
https://www.publicmobile.ca/en/on/get-started
04-14-2020 01:05 PM - edited 04-14-2020 01:06 PM
